Old 04-27-2006   #61
iceminion
iceminion's Avatar
Re: E85
Originally Posted by desolate
It's funny to go and pull up to an E-85 pump and the instore goes "does your car take that stuff?!"
Wait.....so are you running stock internal dsm fuel components and you are seeing no problems? I never believed that bs about it "corroding" aluminum....but you never know...
so are all DSMs just a A/F adjustment away from running e85?
Old 04-27-2006   #62
Gravy
Who's this guy?
Re: E85
And a time bomb for lines to just disapear on you.
It does eat up the DSM gas lines, but it takes some time. If you want, run the fuel, or about a 1/4 tank to find out. If it is bad you can always pump the tank and just run a little rough for a while. It won't mess up your O2 sensor, they had a few bad batches when it first started coming out that scared everyone away. They had too much water in it, and was fouling up O2 sensors even on vehicles equiped to run it.
Old 04-27-2006   #63
tim
tim's Avatar
Re: E85
From what I understand e85 will take a long ass time to corrode lines and dry out seals. It isnt nearly as corrosive as Methanol but since they are both alchohols people tend to associate them both as a big no no for stock fuel systems.
Old 04-27-2006   #64
Gravy
Who's this guy?
Re: E85
Main problem is tuning, it will probably break some seal on these older DSM's with stock lines and O-rings. But for the normal, or "New" parts. You should have some time on them.
Talking on another form about running a N/A car with E-85 for hp gains.... can we say 11:1 compresion ratio?
Old 04-27-2006   #65
iceminion
iceminion's Avatar
Re: E85
I am fully aware of the risk, and if it corrodes throught my stock fuel line, I shall just run a new SS one..... thank you tim for clearing up the methanol/ethanol differences.
So, -IF- i was gonna do this, would a SAFC1/2 work? from what I can remember you can load up 2 different fuel maps, depending on what fuel you are running.
So, is it that easy? just a safc re-tune?
one additional point, as I understand it, there is alot of clay and other anti-engine sediments in standard gasoline, and ethanol has (almost) none.....so engine wear is going to be cut way back......I spose nobody cares here because we rebuild our engines periodically anyways
Old 04-27-2006   #66
Re: E85
11:1 isn't that high for an import. S2000s come stock at 11:1 compression ratio and add boost to those on pump gas. I have tuned 12.5:1 compression dail driven pump gas Honda's before. The gain from going that high really isn't worth it though. The power returns diminish more and more as you go higher and higher.
Old 04-27-2006   #67
Gravy
Who's this guy?
Re: E85
Along with an SAFC you'll need injectors, i'd go 650+ since you'll have the safc to control them, 190 or larger to help get the extra fuel you'll need.
With that you'll be running ethanol in your car, and just have to wait for the lines to corode away. If they do that is, havn't found solid proof it will. Only speculation and proof that alcohol does.
Old 04-27-2006   #68
fievel
Re: E85
Stupid zombie thread, I started reading the first page and saw a post from mike (raptor) and I thought it was private eye time.
fievel is offline   Reply With Quote
Old 04-27-2006   #69
iceminion
iceminion's Avatar
Re: E85
I finally have a sig with information on my car so people can stop assuming im a freaken noob (all my fault)
So yeah, after I get all the oil leaks fixed on my car its gonna be time for the e85
building a 3000GT AWD Turbo.
Old 04-27-2006   #70
CDeutsch
CDeutsch's Avatar
Re: E85
Does E85 not ignite like gasoline? Replacing a fuel line is one thing, but what if your car starts on fire before you notice you have a problem?
06 Evo IX RS
99 Miata
Old 04-27-2006   #71
Gravy
Who's this guy?
Re: E85
First off, if your car starts on fire, you probably have a gas leak somewhere.
As long as your not like me, and forget to plug in your fuel rail, you'll be perfectly fine.
Old 04-27-2006   #72
iceminion
iceminion's Avatar
Re: E85
Old 07-06-2006   #73
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
Re: E85
Anyone got this going yet? Back from the dead!!! I'm kinda thinking about it.
Tyler Aherns
-USN-
Old 07-06-2006   #74
Thor06
11 Seconds to Freedom
Thor06's Avatar
Re: E85
I was too, but I would rather have it running now than waiting to get the conversion done and having to pay for it all.
Old 07-06-2006   #75
CDeutsch
CDeutsch's Avatar
Re: E85
I have some 1600cc injectors on order. I'll let you know how it goes.
It was going pretty good for Jim (TalonFiero) and the curiosity finally got to me so I'm going to see if it allows me to run more boost in my Talon.
06 Evo IX RS
99 Miata
Old 07-06-2006   #76
98gstaherns
Re: E85
Do you need injectors that big? Or would 550's work?
Tyler Aherns
-USN-
Old 07-06-2006   #77
CDeutsch
CDeutsch's Avatar
Re: E85
I'm running a 2.4 with a 50 trim and I use DSMLink so I figured why not. 780's weren't cutting it.
550's may work on a stock car running stock boost.
When picking an injector size you'll also need to determine wether you're going to run straight E85 or a mix.
06 Evo IX RS
99 Miata
Old 07-06-2006   #78
98gstaherns
Re: E85
Sorry I didn't mean as asking do YOU need them I meant in gernal for e85..Sorry I'm dump somtimes. Gotya! Thanks
Tyler Aherns
-USN-
Old 07-07-2006   #79
Re: E85
E85 requires a lot more fuel flow, so you need much bigger than normal injectors and a fuel pump(s) to back it.
Old 07-07-2006   #80
Re: E85
I need to start looking into this as an option for the Jeep. That big V8 drinks like a fish.
