Old 05-28-2004   #1
Can we put this in our cars? what is the octane rating? anybody know anything about this shit? BTW its 85% ethenol gas
Old 05-28-2004   #2
octane rating 109ish, no our cars aren't designed to burn this shit, lightening gsx wants to have his car running on it, it was discussed elsewhere on this board.
SEARCH!
or just pm eric (lightening gsx).
Old 05-28-2004   #3
LightningGSX
Hellbound
Yeah, it needs to be ran at about a 10:1 A/F ratio.You'll need to swap any rubber seals that come in contact with it, over to Teflon or similar.It will corrode anything made from aluminum, so you may need to swap fuel lines, fuel rail, etc(I'm not sure what everything is made of yet).And finally E85 will conduct electricity(gas does not), so you'd need to shield/ground the fuel pump.The OEMs put a flame arrestor in the filler neck, which would probably be a good thing for us also.Its not as difficult as it sounds, I'll let people know once I figure everything out.
Oh yeah, you'll end up with about 20%-30% less fuel economy and the octane rating is between 95 and 105(depending on season and area, I keep meaning to stop by an E85 pump and check the octane rating around here)
-Nulli Secundus-
Old 05-28-2004   #4
So basically it is cheaper just to run race-gas rather than converting everything over then loosing fuel economy.
Old 05-28-2004   #5
LightningGSX
Hellbound
No not really, E85 is alot cheaper, even cheaper than 87 octane unleaded.And it comes from Minnesota farmers, not some foreign oil cartel.
-Nulli Secundus-
Old 05-28-2004   #6
Here's an interesting thread on Tuners about using ethanol for some reference: http://www.dsmtuners.com/forums/showthread...ghlight=Ethanol
Old 05-28-2004   #7
E85 is normally $.40 cheaper than 92. If you put in 12 gallons that is about $5.00 a fill up. It wouldn't take too long to pay itself off. Not to mention you could run 28 - 30 psi EVERY DAY!!
Old 05-28-2004   #8
Originally posted by LightningGSX@May 28 2004, 03:12 AM
.....And it comes from Minnesota farmers, not some foreign oil cartel.
Hell Yeah!!!
Old 05-28-2004   #9
Ahhh, yes! The battle between me an MNGSX! I had to learn him a little Too bad I wasn't able to stay involved in the thread. There are some more things that we were still arguing about. There are some good facts in there though (don't believe all of his though).
Old 05-28-2004   #10
Originally posted by JET+May 28 2004, 07:56 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (JET @ May 28 2004, 07:56 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Jakey@May 28 2004, 06:52 AM
Ahhh, yes! The battle between me an MNGSX! I had to learn him a little Too bad I wasn't able to stay involved in the thread. There are some more things that we were still arguing about. There are some good facts in there though (don't believe all of his though). [/b][/quote]
I thought you might like that.
Old 05-28-2004   #11
Although you must remember you will be losing about 20-30% of your fuel economy so in effect it is not truely $5 cheaper/tank if you take in to account the fact you will have to refuel more often. My old roomate has an '00 Ford Ranger than can run on either regular gasoline or E85, and after using both for extended periods of time he found it was cheaper just to run the regular 87-octane gasoline. One more thing, I am sick of having to bail out the MN farmers. If they can't survive they should just go out of business like would happen in any other industry. We already help them out enough with the price-floor put in place for milk. That stuff is over $4/gal now at Cub last time I checked. Whenever possibly I liked to get the nonoxygenated fuel for my Talon, it seemed to run better and I did get a few extra MPG.
Old 05-29-2004   #12
LightningGSX
Hellbound
When you're running 92 octane to begin with, E85 will be alot more economical and have other benefits as well.I actually think it would be possible to get nearly the same fuel ecomony with a turbo DSM and E85.I'll find out soon enough.
-Nulli Secundus-
Old 05-29-2004   #13
Originally posted by TalonTSiDude+May 28 2004, 11:50 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (TalonTSiDude @ May 28 2004, 11:50 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-JET@May 28 2004, 07:52 AM
E85 is normally $.40 cheaper than 92.&nbsp; If you put in 12 gallons that is about $5.00 a fill up.&nbsp; It wouldn't take too long to pay itself off.&nbsp; Not to mention you could run 28 - 30 psi EVERY DAY!!
Although you must remember you will be losing about 20-30% of your fuel economy so in effect it is not truely $5 cheaper/tank if you take in to account the fact you will have to refuel more often. My old roomate has an '00 Ford Ranger than can run on either regular gasoline or E85, and after using both for extended periods of time he found it was cheaper just to run the regular 87-octane gasoline. One more thing, I am sick of having to bail out the MN farmers. If they can't survive they should just go out of business like would happen in any other industry. We already help them out enough with the price-floor put in place for milk. That stuff is over $4/gal now at Cub last time I checked. Whenever possibly I liked to get the nonoxygenated fuel for my Talon, it seemed to run better and I did get a few extra MPG. [/b][/quote]
You may want to rethink your comment which is bashing those who the entire Minnesota economy is built around.
Old 05-29-2004   #14
Emcee gsxtc
Emcee gsxtc's Avatar
Originally posted by Jakey+May 29 2004, 10:12 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Jakey @ May 29 2004, 10:12 AM)</td></tr><tr><td id='QUOTE'>
Originally posted by TalonTSiDude@May 28 2004, 11:50 PM
<!--QuoteBegin-JET
E85 is normally $.40 cheaper than 92.Â* If you put in 12 gallons that is about $5.00 a fill up.Â* It wouldn't take too long to pay itself off.Â* Not to mention you could run 28 - 30 psi EVERY DAY!!
You may want to rethink your comment which is bashing those who the entire Minnesota economy is built around. [/b][/quote]
Ditto - Dont piss in the pool you swim in, its not healthy.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 05-29-2004   #15
Originally posted by TalonTSiDude@May 28 2004, 10:50 PM
One more thing, I am sick of having to bail out the MN farmers.&nbsp; If they can't survive they should just go out of business like would happen in any other industry.&nbsp; We already help them out enough with the price-floor put in place for milk.&nbsp; That stuff is over $4/gal now at Cub last time I checked.
Have you ever visited a dairy farm? Have you ever talked to a farmer about anything at all related to their business? If you knew how close every privately owned farm is to going under you'd understand.
There is an ethanol plant just east of Owatonna. Local farmers were given huge contracts to sell their corn to the plant, and as a result they're able to buy more land, plant more crops and buy bigger and better equipment to get the job done. On top of it, they get a better way of life and more security while we get cheaper and cleaner burning fuel.
Old 05-29-2004   #16
Originally posted by Matt D.@May 29 2004, 01:08 PM
Have you ever talked to a farmer about anything at all related to their business?&nbsp; If you knew how close every privately owned farm is to going under you'd understand.
There is an ethanol plant just east of Owatonna.&nbsp; Local farmers were given huge contracts to sell their corn to the plant, and as a result they're able to buy more land, plant more crops and buy bigger and better equipment to get the job done.&nbsp; On top of it, they get a better way of life and more security while we get cheaper and cleaner burning fuel.
Yeah, my family's farm went under, so the fuck what? Seriously, if you can't hack it in the business then you shouldn't be in it. Nobody in my family pissed and moaned; they realized their time was up, sold most of the equipment and most the land. And did I mention I am a fag? The few remaining fields we own are either being rented out or are on the idle-land revitilization program.
Don't talk about "cleaner burning" either, 90% of the cars on this board are emissions illegal.
About the price...I regularly paid the extra $.10/gal to get the nonoxygenated gasoline if the station I was at offered it and generally noted a slight increase in performance and always a few extra MPG.
Old 05-29-2004   #17
Ethanol is cleaner burning than gasoline last I knew. Obviously you can't expect to just dump it into any car and see immediate results... Hence why Eric is working on converting to E85.
Concerning the price of milk: There will always be a demand, and people will pay nearly anything for it. If you ask me it's not all that rediculous of a price. I think I paid less than $6 at Cub for two gallons.
Old 05-30-2004   #18
LightningGSX
Hellbound
The oxygenated gas is E5(5% ethanol) I believe, older vehicles aren't really programmed to run on it.If you have a vehicle equipped to run any combo of ethanol, the upsides outway the downsides by far.
And you can't honestly tell me you'd rather give your money to a foreigner, over an american farmer, could you?
-Nulli Secundus-
Old 05-30-2004   #19
All gas (unless stated as nonoxygenated) is 10% ethanol in MN. They actually made it a law a year or 2 ago. I looked it up a month or 2 ago. That is year round too.
Old 05-30-2004   #20
I'd rather get what I pay for. If I want corn I go to the grocery store; if I want gas I go to the gas station. If the farmers made quality gasoline I would purchase it from them rather than from overseas, but they don't, they grow vegatables.
