Old 11-12-2008   #101
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: bad idea or terrible idea?
This engine block was found out of a U pull yard
Hopefully everything is going to work out. I thought the engine was there because of Turbo or electrical problem (for example I found a new coil pack) but hopefully the engine block is fine
I want to know what kind of smoke is coming out the back? also are you using the head it came with and did you replace the valve seals?
Old 11-12-2008   #102
