Old 02-09-2010   #41
way2fastalon
IS Broken :-/
way2fastalon's Avatar
Talking Re: 1991 talon 500 hp project
SO..
today i spent about an hour at map getting things together and this is what i bought ..
wiseco pistons 8:3:1 cr 20+
eagle rods
acl race main and rod bearings
arp main studs
oem 2.0 crankshaft
balance shaft elimination kit
new aem wideband 02 sensor
$1298.00
was thinking about those wossner pistons but i haven't been able to find anything about them ...
before i picked up that stuff at map i went and got 850cc injectors and the snow performance kit methanol injection stage 2 ... thanks red-line nice 35r .
planning on taking out the engine this weekend or next weekend will post pictures
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 02-09-2010   #42
Nice list. Only comments I have are why did you need a new Crank? Also in my opinion you probably could have gotten away with stock main hardware and saved some money by not getting the ARP's. But to each their own, good luck man! The more fast purple 1g's around, the better
Old 02-09-2010   #43
I havent SEEN any around? lol
Sounds like quite a list you got there, good luck
Old 02-10-2010   #44
b00sted_spyder
Originally Posted by way2fastlaser View Post
here are the pictures of the turbo i got
Attachment 9644
Attachment 9645
Attachment 9646
Attachment 9647
That turbo looks like it has blown seals. Exhaust wheel is wet...but if you need a t3 turbo manifold, I have one. Ramhorn style made by Punishment Racing.
Old 02-10-2010   #45
way2fastalon
IS Broken :-/
i needed it cause i think mine is thrashed cause its knocking map sold me one for $ 280 +( its going to need a polish )
the arp's i thought would make my engine stronger and safer.yeah i could have saved some money on a few things but i have the worst luck when it comes to engines and i just dont want to cheap out on some parts and be broken down some where.
+more mods to list
Old 02-10-2010   #46
I hear ya. I'm still on stock main hardware so that's why I think you'd be ok too. But if it's worth it to you to get em, then more power to ya! Better safe then sorry isn't a bad mindset.
Old 02-10-2010   #47
$280 for a 6 bolt 2.0 crank that needs a polish?? Are they getting hard to find or something? I got one from them about 2 and a half years ago for $75.
Old 02-10-2010   #48
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Yea damn...that's a hefty pricetag for a stock crank.
Old 02-10-2010   #49
93tsiawd
Drives: 90 gst
i would have sold you a stock crank for $50
99 Jaguar XJ8 (cruiser)
96 Civic Ex (sold)
90 Eclipse GS-T (sold)
90 Talon Tsi Awd (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
93tsiawd is offline   Reply With Quote
Old 02-10-2010   #50
way2fastalon
IS Broken :-/
here is my kit and parts i have got so far
+more mods to list
Old 02-10-2010   #51
Dont you need to line hone when you use arp main studs?
Old 02-10-2010   #52
^Thats what I have heard.
Old 02-10-2010   #53
Maybe, maybe not, depends on your exact block. ARP mains aren't needed for most builds, but they are probably cheaper than getting a new stock set of main bolts for the non-reusable ones on the 7-bolts and Evos. I would do some ARP L19 or A1 H11 headstuds before even doing rods/pistons. The heads usually start lifting before you even reach the limits of the stock rods/pistons in a 6-bolt motor. And normal ARP head studs are next to worthless over the stock bolts in DSMs/Evos.
Old 02-10-2010   #54
mike55112
mike55112's Avatar
Drives: 04 evo
Thats true, my last set of arp's stretched really bad and caused my cometic HG to split on cylinder number 1. I'm planning on getting the L19's this summer.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 02-10-2010   #55
way2fastalon
IS Broken :-/
i have to upgrade my head studs ? i just got these. haven't even seen 300 mi or even 20 psi of boost .
+more mods to list
Old 02-10-2010   #56
If you plan on running the boost neccessary to make 500hp on DB's dyno, L19's would probably be a worthwhile investment.
Old 02-11-2010   #57
way2fastalon
IS Broken :-/
and i thought i was done spending money
+more mods to list
Old 02-11-2010   #58
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
There is a huge thread on dsmtalk talking about how shitty the standard ARP headstuds are. Stock 6bolt head "bolts" are actually stronger than the standard ARP's.
-1990 Mitsubishi Cyborg 4WD-
Old 02-11-2010   #59
way2fastalon
IS Broken :-/
dammit anyone want to sell me some L19s
+more mods to list
Old 02-11-2010   #60
now that you know to talk to craig at oreilly's and use are mitsustyle discount you could have saved a ton of cash on all the parts you just bought. with are discount there it is cheaper than any local shop
