Old 01-26-2010   #1
way2fastalon
IS Broken :-/
way2fastalon's Avatar
Talking 1991 talon 500 hp project
I Thought it would be appropriate to start a build thread
I have a 1991 awd Talon bought it for $1000 with a blown engine body is 9/10 its almost perfect. I dident care much about the interior its about 7/10 some rips in the leather seats . no headliner
Name:	my talon.jpg
now on my 3rd engine going on 4th
The first one had a bad rod knock spun a rod bearing + it was a 7 bolt the guy before me must have put that in there. So i bought the 2nd engine was also a 7 bolt for $450 complete bought that to put in for just getting the car going got it in there got it running not even 2 days it exploded a piston and rod thru the oil pan and cracked my bellhousing my girlfriend was driving it to work in stillwater and im guessing the oil pump stopped working or i got detonation some how on stock boost witch was at 10psi on 14b with open down pipe .? but anyways that's still sitting in the garage with a hole in the block on both sides .[ATTACH]9618[ATTACH]9619
now i wised up and got a 6 bolt short block from grease monkey
i took it apart to inspect it and the rods had a little play seemed normal for an old engine ..? pulled the balance shafts out and put the plugs in there and called it good put my good head on there and arp head studs torqued everything down to 80 did the cams at 40 got the gates blue T-belt got everything ready to go and to be fired up primed it before i put the belt on and put the belt on and it started up ran nice still had the oil pressure problum about 20 at idle with 10w40 every one told me that was norm and it was like 50-60 at hiway speeds and under full boost it stayed at 60 !
so i knew it was a matter of time before it woluld start knocking .. so a month later i was out tuning it with dsmlink and i got like 5 deg knock at 18psi and my afr was 10:8 11:0 in 3rd wot i just couldent get it to stay stedy it wanted less fuel and i took some out and it liked it and then i added 2-3 degrees of timing in the 4-5k and did another pull and it started to knock
thought dsm link had a stock tune for it self when i loaded that it ran like shit no power at all but when i was tuning i was verry conservitive i had 110 and 93 in the tank.. i only raised the timing like 2-3 deg and added and removed fuel 2-3 till it started to make power . so now i decided to take it to the masters of thease beasts db tuning and not destroy another engine ..
so here is the build
Jasons car quest to 500 awhp
1.aem 02 sensor 60.00 cooked myold 1
2.pistons+rods wiseco hd pistons and eagle rods $400-700
3.acl racing rod and main berings $100
4.machine work $140 D and D + head and block decked
5.methaol injection kit stage 2 $ 300
6.headgasket kit $ 70-100
7.big brake kit 2g calpers $150
8.injectors 1000-1600cc $300
9.afpr aem or some other brand $160
10.rewire fuel pump and run bigger lines $80
11.brian crower cams 272s $360
12.valve springs and steel valves $400
13.fmic kit at least 400 hp or 700cfm $250 cx racing or fantasy motar sports
14. bov and pipe $ 130-170 greddy or hks
15.tial waste gate $100-150
16.2g maf i have .need intake charge pipe
17.lph 255 have installed
18.dsmlink v.2.5 have installed
19.get head ceramic coated ?
20 fp evo3 16g have installed
21.megan 3in downpipe 3in to cherry bomb then in to a apexi n1 installed
suggestions on parts or better for the money would be appreciated
i haven't bought anything yet other than stated i do plan on running e85 or 110
if you would like to sell me some parts pm me im looking and pricing out things now so far im about 3000+ what i have to spend is about 1500
so there are some things that are going to have to wait ..
Here is some pictures of the destroyed 7 bolt some people have seen this some haven't enjoy thanks for looking
Name:	big hole in my pan.jpg
ID:	9618   Click image for larger version
ID:	9619   Click image for larger version
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
