03-19-2011
Drives: 98 Eclipse GST/ 90 Laser RS
2g With 6 Bolt... Problems
I finished getting my 6 bolt into my 2g. When I start it the rpm's shoot to around 4k and it runs smooth. Then the rpm's will start to drop and it runs really rough (by that time I usually shut it off.) And the power steering resevoir starts to overflow and foam out of the cap. WTF? Any ideas? BTW, it's a stock 6 bolt with 272 cams... formerly C3L1CA/ MunchGSX's motor. I'm running on the stock 97 ecu in my car, but i have that CAS adapter harness from Magnus.
I bet that you have no idea of the hell I've been through in the last couple months. But I'm still smiling. Thank you lord, you've given me the most beautiful set of wings. And thanks to all my friends that helped me keep my head up.
03-19-2011
Drives: cbr 1000rr repsol
Re: 2g With 6 Bolt... Problems
Do you have a cel light?
03-19-2011
AznKraut
Is your BISS in there?
03-19-2011
nope. and yes ling ling the BISS is in there.
03-19-2011
You proably have a boost/ vacaum leak. Double check everything. Do a boost leak. And its not going to idle good with cams on stock ecu
03-20-2011
Paul, come help me out with the vacuum lines.
03-20-2011
Drives: You crazy!
Just got off work. Any progress?
03-20-2011
None :/
03-20-2011
AznKraut
^^This.
Grab a spray bottle of soapy water, spray all the IC pipe joints, some around your TB and check to see if your DV is leaking.
+1 On the stock ECU with cams too. Not sure how that is gonna work lol.
03-20-2011
Originally Posted by LingLing
^^This.
I'll give it a shot.
03-20-2011
AznKraut
Thought of another thing while wrenching on the Talon tonight. Check to see if your CAS is set correctly.
03-20-2011
I have no clue how to set it.
03-21-2011
03-21-2011
Originally Posted by b00sted_spyder
I thought 6 bolt motors didn't have crank angle sensors? Just cam angle?
03-21-2011
CAS should be fine as long as you didn't take it off or play with it.
What injectors do you have in it? Is it doing anything else weird?
03-21-2011
That's the cam angle sensor. Just ignore the crank word in that picture. But that's how you install the CAS.
03-21-2011
Just stock injectors. It just idles up to like 4 grand and drops down really low like it wants to kill itself.
03-21-2011
Drives: You crazy!
Im heading down to maplewood to grab some stuff from Brad i can stop by on my way home and look it over. Also grab that hoist. LOL
03-22-2011
#19
She's running good now  )
03-22-2011
#20
What ended up being the fix?
| Thread Tools |
| Display Modes |
Linear Mode
