Old 03-20-2011   #7
LingLing
AznKraut
LingLing's Avatar
Re: 2g With 6 Bolt... Problems
You proably have a boost/ vacaum leak. Double check everything. Do a boost leak. And its not going to idle good with cams on stock ecu
^^This.
Grab a spray bottle of soapy water, spray all the IC pipe joints, some around your TB and check to see if your DV is leaking.
+1 On the stock ECU with cams too. Not sure how that is gonna work lol.
