Old 03-29-2013   #161
Re: 1g 6 bolt 4g63 tsi build
Wow car is looking good! New mods look awesome.
Old 04-03-2013   #162
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Originally Posted by blackrosenova400 View Post
Those blue lcd's are pretty nice.
Thanks guys!
Old 04-03-2013   #163
dsmghost
dsmghost's Avatar
Still waiting for a solution from Prosport about the faulty pressure sender.
Over the winter it has been fine, but since its gotten warmer the sunroof leaks. It leaks only under the high pressure spray in the car wash. I pulled out the sunroof, everything, and resealed the frame that holds the glass. Took it through the car wash today and no more leak!
Old 05-01-2013   #164
dsmghost
dsmghost's Avatar
Getting tuned on the 15th. Switching to E85 so next time I need to, I'll fill it with "E85".
Link wise, what do I do to drive away from the e85 pump?
All I need to do is adjust for aprox 33% more fuel keeping fuel trims in check correct? What a/f ratios should I be looking for?
Old 05-01-2013   #165
Yea, add 35% fuel, AFR should remain the same on the gas scale, so 14.7:1 cruise and 11.5:1 WOT for starters.
I would get the STFT and LTFT as close to 0 as possible before your tune.
Old 05-02-2013   #166
dsmghost
dsmghost's Avatar
Ok cool thanks. Filled with ethanol today. Got it all sorted out. I didnt have to add that much yet since i'm running a mixture with gas still.
Old 05-02-2013   #167
dsmghost
dsmghost's Avatar
Do it!! The only regret you'll have is wishing you'd have done it sooner
You were right! I seriously feel stupid for not switching a long time ago.
Name:	E85 Talon.jpg
Old 05-02-2013   #168
Told ya! Just wait till you get it tuned by Shane! You'll be blown away I promise
I wish I had that day off to come watch, but I'll have to come down and check it out afterwards or something.
Old 05-03-2013   #169
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
And don't blow it up before you get tuned lol
2006 WW IX RS 396/404 - SOLD
Old 05-03-2013   #170
Pretty tough to blow it up unless you are doing pulls. And who does that? Seems like you are asking for trouble.
I forgot to mention (and I hope you realized this already), but you don't add 35% in DSMlink to the global fuel compensation. You basically scale the injector down 35% and then input that setting for the injector. So for 1650cc you would have -72%, but on E85 they act like 1220cc which would be -63%. Hope that makes sense. Just watch your short and long term fuel trims and make them zero, that's all that matters.
Old 05-03-2013   #171
dsmghost
dsmghost's Avatar
Yeah, I got it. It's running very well. I'm monitoring everything very closely. And obviously, ill be making more adjustments next time I fill the tank since I'm still diluting out gasoline.
Old 05-03-2013   #172
dsmghost
dsmghost's Avatar
Yeah, it will be a little different than last time with the 14b and 450s
Old 05-06-2013   #173
dsmghost
dsmghost's Avatar
I filled it up with E85 again today, had the laptop with so I could adjust for the new mixture in the tank (still diluting gas out of tank). Everything was running fine until during a cruise my fuel trims start going crazy, my wideband was showing that it wasnt cutting fuel on decel. I pulled off and let it idle, something was definitely wrong. The car would barely idle, So I pulled the vacuum line of my AFPR, yup it was dumping fuel in the vacuum line. Threw on a stock regulator and its good to go.
I'm going to pull the AFPR apart tomorrow to see what's going on with the diaphragm. I'm wondering if the E85 has anything to do with the sudden failure of the regulator.
Old 05-07-2013   #174
^The e85 won't wreck a regulator, especially that fast. Glad you got it figured out so quick. You don't want problems before a tune. Make sure to do a boost leak test and have NO leaks before your tune as well.
Old 05-08-2013   #175
dsmghost
dsmghost's Avatar
So this morning I pulled the transmission so I could replace the output shaft seal. Its been leaking since day 1. I overlooked that seal when assembling the car, although I replaced both axle seals at the time. Over winter it was fine couple drips under the car, since its been warm the leak got much much worse. Glad I finally took care of that seal, while I was in there inspected the clutch, throw out bearing etc.. All was good.
Also, I ordered a mishimoto fan to aid the single flex a lite fan with cooling, it showed up today. Ill be installing that very soon. I've been running about 210*F cruising, is that normal or should I be looking to drop engine temps more?
Old 05-15-2013   #176
dsmghost
dsmghost's Avatar
Well, 292hp/285tq, Shootout mode was 343hp/336tq.
Im happy, but did not hit the numbers I was hoping for.
ID:	13611   Click image for larger version
Old 05-15-2013   #177
Looks like it needs some cams and more boost! How does it feel on the road compared to before?
Old 05-15-2013   #178
dsmghost
dsmghost's Avatar
It is a lot smoother, better drivability. Spool up seems smooth and solid. He did a pull before any tuning, it hit 248 at around 24 psi I think. Seemed to lose power anything more than the 27psi it's set at now. Maybe Shane will chime in with more info.
Old 05-15-2013   #179
dsmghost
dsmghost's Avatar
So I was expecting more power from this ef1. Suggestions?
How much gain could I expect from different cams?
How much power could my 255 and 1250cc injectors support?
My only boost leak is very minimal at the throttle body shaft seal. Going to be addressed very soon.
Aaron, Carl and Nick all ran low 11s at 120mph. What cams, injectors, boost were you guys running?
Old 05-15-2013   #180
I would say the turbo is easily capable of 350-360 with good cams and an intake manifold. Your fuel system should support low to mid 400s.
