Old 07-05-2014   #1
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
Where does this sensor go?
I am almost done putting my car back together after having the head off. I cannot figure out where this hooks up to. I know it is the cam position sensor and it sits behind the intake cam, but I have no idea where the connector plugs into.
Please help! Im hoping to get this running asap.
Thanks,
Cole
ID:	14539   Click image for larger version
ID:	14540   Click image for larger version
mitsukid124 is offline   Reply With Quote
Old 07-05-2014   #2
mitsukid124
Re: Where does this sensor go?
I think it might have been on there still from when the previous owner put a JDM engine into it. It has the CAS on the passenger side of the intake cam and that is actually hooked up.
So my question now is, do I even need this?
Old 07-05-2014   #3
If you have a 1g cas you do not need that one
Old 07-05-2014   #4
mitsukid124
This is a pic of what I believe is a cam position sensor that is on the passenger side of the intake cam.
mark can you confirm this for me or not?
Old 07-05-2014   #5
That's a 97-99 cas.
Old 07-05-2014   #6
mitsukid124
So then I need both? the other one feeds the ecu ignition timing right?
Old 07-05-2014   #7
You need the 97 cas and the crank sensor
Or
95-96 cas behind the cam gear and crank sensor.
Just depends in the cas plug on the harness 95-96 or 97-99
Old 07-05-2014   #8
mitsukid124
ok, that makes more sense, now I just have to find where the cas behind the cam gear plug into. I see nothing that has a square plug.
Old 07-05-2014   #9
mitsukid124
Is anyone with this style plug (from the original post) able to chase the wires in their car and see where it connects to and where that connector is located?
Old 07-06-2014   #10
PIITB!
Old 07-06-2014   #11
mitsukid124
That wouldn't get my car running haha.
Old 07-06-2014   #12
If it's in the 97 it will not have a plug for the cam gear cas. Just will have the crank plug and cas plug on the pass side for the 97+ cas
Old 07-06-2014   #13
mitsukid124
so this pic is the crank sensor right? I feel like missing something here, but if I truly have no need for the sensor behind the cam gears and only the sensors in this post then I can take that out? no harm to anything?
Name:	crank sensor.jpg
ID:	14543   Click image for larger version
Old 07-06-2014   #14
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
95 and 96 had the cam sensor behind the cam gear. All others had it on the end of the cam. It looks like you have a 97-99 style cam sensor so you shouldn't need the one behind the gear.
11.35 @ 120mph
Old 07-06-2014   #15
mitsukid124
Ok cool, that'll be $45 back in my pocket. I replaced it because the sensor was broke. Thank you guys for the help!
