Old 01-08-2015   #41
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Re: 800 hp goal Dsm build
As far as i know thats pretty much the biggest thing it helps with Shane. But im not the one to talk i dont know much about it. Still looking into it
Tyler
2011 Subaru Sti 11.0 @135mph
Old 01-08-2015   #42
The main problem is the gears shredding apart where they mesh from power. Shifting is usually a clutch problem or worn syncro problem with DSMs.
Old 01-08-2015   #43
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Think thats why face plating helps out a ton. Bigger teath so allows more room to find the gear easier. There for less shredding.
Tyler
Old 01-08-2015   #44
The part of the gear/syncro/hub that does the shifting is not the part that holds the power though. Gears usually shred apart after the shift is done and not from the shift.
The pointy house shaped part of the gear would be replaced by face plating, not the part that is destroyed in this picture of a typical broken DSM gear.
Old 01-08-2015   #45
URV8SUX
URV8SUX's Avatar
Does face plating help besides with high rpm shifting and making it worse to drive on the street?
It just has less things to engage but if its put together wrong it won't shift for shit anyways.
http://www.libertysgears.com/faceplate.htm
Old 01-08-2015   #46
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Ahh i see it now. Think i got the idea
Tyler
Old 01-11-2015   #47
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Got the 6 bolt i had bought a bit ago ready to get to gosh. Bearings inside were a little rough. Also found it had been apart before it had arp main studs with arp rod bolts.
ID:	14918   Click image for larger version
Tyler
