Old 01-05-2015   #1
dsmDolney
dsmDolney's Avatar
Drives: Racecars
800 hp goal Dsm build
Figured id start a new thread for this years winter/spring build and all the rest off the stuff that goes down with the car.
Specs:
1995 eclipse gst awd converted
Welded diff
Gutted
All autometer carbon fiber gauges : boost, oil pressure, coolant temp
Battery relocated to the trunk with cutoff switch
Thats all as far as the car sits right now.
List for this winter :
Pte 6766 .96 a/r undivided t4 (have)
6 bolt 2.0 .020 block
Pauter rods
Wiseco 1400 hd 10.5.1 pistons
Stock polished and balanced crank
6 bolt stockport head (have)
GSC s3 cams
GSC adjustable cam gears (have)
GSC power division springs and retainers
GSC power division zero tick lifters
GSC valve stem seals
Supertech valve guids
Not sure on valves yet standard size tho
Arp hardware
Kiggly main griddle
Acl bearings
Built trans (not sure who yet)
SD
Jmfab drag intake manifold
Theres the plans for the motor some things i havnt decided on quite yet but input is good. Kind of a big goal for me right out of the gate but go big or go home. Alot of time and money will be invested and cant wait to start putting her back together. Will keep posting updates as the build continues. Enjoy
ID:	14888   Click image for larger version
Tyler
2011 Subaru Sti 11.0 @135mph
Old 01-05-2015   #2
Dark2g
Drives: 2gb gsx
Re: 800 hp goal Dsm build
Nice man, this should be a fun build! What are your fuel plans?
Old 01-06-2015   #3
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
I can guide you in a few things like valves and HLAs. Plus save you money!
Old 01-06-2015   #4
Is this for a dyno queen or drag setup?
Old 01-06-2015   #5
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Fuel plans i forgot to put in there... Dang. I am not sure on it yet to tell you the truth i know i want to go with a single pump tho no dual pumps
Also any help and input is great i always am down to hear what people think. And i like saving money
This is for a drag setup id like to get to the track alot when the car is finished put my money to use atleast
Tyler
Old 01-06-2015   #6
Looking forward to seeing this done.
Old 01-06-2015   #7
Car looks nice and sounds like it'll be a beast when done. Good luck!
Old 01-06-2015   #8
Should go auto then imo. Lag monster
Old 01-06-2015   #9
x-pride
x-pride's Avatar
How high does your boost gauge go up to?
Old 01-06-2015   #10
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Thanks guys appreciate it with the positive comments.
Auto i was thinking but ill try out manual this year and see how it goes
Boost gauge not high enough so ill be getting a new one
Tyler
Old 01-06-2015   #11
DSMINMN
Mitsus for days!
DSMINMN's Avatar
http://www.ebay.com/itm/4G63-Mitsubi...item58bc0966b4
That is what you want. They're good quality parts that multiple people are running at 800 or more horsepower. I as well as others have made threads asking about them and the response is always positive.
The only downside with bronze valve guides is you'll have to pay a bit to have them honed when they're installed. You won't be able to avoid this no matter the brand. Why not save money on the three and put what you save towards the machine work? My way to look at it.
If you're needing machine work or just want your block cleaned of flashing I'm your guy. I've got pictures somewhere of my buddies block I have a good 10 hours into just flashing and casting flaw removal. Just something to consider.
Old 01-06-2015   #12
dsmDolney
dsmDolney's Avatar
Drives: Racecars
I might have to lend you my block depending on price
Tyler
Old 01-06-2015   #13
x-pride
x-pride's Avatar
I know it sound like a silly question but most people don't realize how fast you can hit past the 30 pound boost with a DSM.
Are you looking at doing 800 at DB or Maps?
Old 01-06-2015   #14
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Itll be at DB
Tyler
Old 01-06-2015   #15
x-pride
x-pride's Avatar
Make sure you post date and time when you dyno! I would like to be there for this dyno session.
Old 01-06-2015   #16
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
800 at DB, that is big time.
This should be a pretty cool build when all is said and done.
Maybe i am wrong on this, isn't the exhaust housing on this turbo a bit small for 800 at DB? I know on my t4 6266 I ran a 1.0A/R but that was twinscroll, so probably not the same at all. Actually the more I think about it, single scroll that is a huge A/R I think.
Carry on
Old 01-06-2015   #17
dsmDolney
dsmDolney's Avatar
Drives: Racecars
It is a pretty big housing for sure. Itll be nice when its done to look at what ive built. 800 is goal even if i come close to it itll make me happy.
Tyler
Old 01-06-2015   #18
If you like to save money go auto
Old 01-06-2015   #19
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Automagic FTW. Saving money with an auto is an understatement. lol
Old 01-06-2015   #20
dsmDolney
dsmDolney's Avatar
Drives: Racecars
I think ill jist stay manual this time and see how it goes if its that bad ill go auto
Tyler
