Old 09-03-2005   #6
Re: did 93 dissapear? why do i only see 92?
Originally Posted by BLIZZARD
non oxygenated gas is only needed when the vehicle is going to not be used in a regular fashion. It doesn't gel up as much after it sits for awhile, you can use stabil to keep it from geling up as well. If you are going to use the gas right away it doesn't matter if its non oxygenated or not. Just use the BP/Amoco or Holiday 93, don't use SA gas though, or Citgo, ect. Unless you want a knock monster.
Where the hell did you get that from? Non-oxygenated means non-ethanol. That means you get a little more power out of it because gas has more energy in it than ethanol.
