Old 05-09-2006   #5
longemoco
Re: replacing my t-belt,
You can turn the sprockets, just make sure to align them all up again when you put on the belts. There are marks to line up on the crank pulley, oil pump pulley, front bs belt pulley and cam gears. The bs belt pulleys can be on the mark in two different positions, only one of them is correct. It's detailed in any repair manual for these.
ok thanks. now i think i might as well replace idler pulley t-belt tensioner, i just put a brand new water pump, what else should i replace?
longemoco is offline   Reply With Quote
