Old 03-07-2008   #7
iceminion
iceminion's Avatar
Re: Venturi vacuum pump
It pulled no vacuum at wot?
yes, I lost a bet with one of my gearhead friends, believe me, I was of the opinion that "this is a crazy idea and will not work"
Lets put it this way, I had the car setup just as it was stock, the turbo pulling on the crank case vent, I had oil leaks everywhere, but due to the (massive) change in diameter of the intake pipe, the stock vacuum line did not pull much(if any) vacuum, and I HAD OIL LEAKS.
all I am saying is this FIXED THE PROBLEM that I have always had, my first TSi AWD (stock) popped the dip stick all the time, and when i let my friends drive the car it would pop and send oil spewing up onto the underside of the hood, make a huge mess of things! I wish I had this then!
building a 3000GT AWD Turbo.
