Old 03-06-2008   #6
Re: Venturi vacuum pump
I guess I should have been more specific about the applications for this pump.
stock cars with stock intake pipes are probably going to be ok.
cars with 4 inch intake pipes coming off the turbo have a problem.
Since the 4 inch intake pipe is such low restriction, there is absolutely no vacuum created by hooking a vacuum line up to the side.
I tested this with a boost gauge, didnt pull any vacuum at all.
again, this is for people who are having problems, if you are not having a problem, nothing to fix right?
It pulled no vacuum at wot?
