Old 10-02-2009   #11
jhaan_dude
jhaan_dude's Avatar
Drives: a car
Re: jhaan_dude is a good guy
yes it needs a restrictor! talk to blackrosenova about this! we have been down this road a million times! if you feed from the head you shouldnt need one, but if you feed from the filter housings you are seeing the full pressure from the pump plus massive volume. since the turbo has a open port on the oil channel it will just poor oil in there at high pressure causing it to blow by the exhaust seal! i had the same problems with blackrosenova's turbo 3 times before he put in a restrictor. now his turbo has zero issues. there is no more to talk about on this subject until i rebuilt it and he puts in a restrictor!
