Old 10-02-2009   #11
santa
Boost Spike
santa's Avatar
Re: jhaan_dude is a good guy
Journal bearing should not need restrictors if oil pressure is in the normal range and if the turbo is properly built. I know that for a fact because I talked to the head guy at PTE themselves and he said. Now a BB turbo will and I got a restrictor for my pte BB turbo from PTE. The guy at Precision said that their journal bearing turbos like alot of oil since they are not water cooled. 4seasons69 just send it in to Precision and have it done right and correct the first time. They are great guys and are willing to explain things and work with you there.
Kerry I agree 100%. I spoke with the lead rebuild guy at pte. He also said my turbo (standard journal 360degree bearing) wants as much oil as I can get it. I wrecked two of my current 67's feeding from the head. He told me go directly from the oil filter housing with NO RESTRICTOR. since then I've had the turbo on my car for 3,000 miles and it has absolutly 0 shaft play and does not push a drop of oil out of either sides of the turbo.
