Old 07-08-2004   #1
Ok hopefully my car will be started tomarrow for the first time. And I want to make sure I hooked everything up correctly.
Basically all I need to make sure of is the MBC, and the External Waiste gate. Everything else should be fine.
-I run an "Extreme" Manual Boost Controller - (looks and works identical to Elite's)
With the knob Facing up"
- the bottom line is "T" to the BOV Line
- The line that goes out the side is connected to the lower nipple on the External waiste gate
is that correct?
As for the Waiste Gate:
-I leave the top "hole" open and only put 1 nipple in on the side for the MBC Line correct?
