Old 08-30-2005   #7
Re: Building a 7 bolt... What clutch?
Originally Posted by EclipseGST
Crank is perfect... One of the rods was scored but I have a different one already. I have the conversation if you want it Josh~
It spun a rod bearing but the crank is perfect? What scored the rod bearing then? Why wouldn't you just replace the rod bearing, unless the bearing welded itself to the crank and actually spun inside the rod. In that case, the crank would definately not be perfect. Has the crank been ground undersized possibly?
I would stick with the DXD and see if it will hold the power. Also install a clutch bypass switch so you don't have to have the clutch in on startup.
