Go Back   MitsuStyle > Hosted Support Forums > LSE Performance
Old 09-13-2005   #2
Re: motor mounts and sway bars
-Sway bar, stock or aftermarket?
-balance shaft elim, as in turned down shaft or the "kit" from mitsu?, Also we can weld the front case, we recommend a new front case and gears though. And we do not do this in car AT ALL, pull the motor out.
-FPR, Aeromotive regulator with a -AN adapter off the stock rail, and gauge as well.
-With the motor mounts I think you need to press the inserts in, after cutting out the stock unit.
We will PM you.
Pushit2.0 is offline
