Go Back   MitsuStyle > The Homefront! > Everything Racing
Old 09-24-2005   #9
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Nopi Nationals Sept 24-25 Moroso
I had this same thing happen on my car... Do you have GM Maf and translator setup? If so, take the cover off the box and make sure its not on RPM mode. If it is and you dont have the white wire plugged into an RPM signal wire you will get a misfire in high RPMs as you described. Happened on my car, switched it back to MAF mode and it worked fine now.
Originally Posted by shoutbox
