Old 09-28-2005   #13
Re: Whistling noise?
Vacuum leak, or maybe a belt is slipping under load, ussually teh AC belt slips and squeels under load, but if the AC is off that should lget rid of that cause. Maybe alternator or PS belts are loose and slip under more load?
Check their tension and then check for vacuum leaks with a stethescope if you have one.
