Go Back   MitsuStyle > The Homefront! > Everything Racing
Old 09-30-2005   #14
Re: Nopi Nationals Sept 24-25 Moroso
#2 and #3 cylinders would be the same coil. If #3 doesn't look too bad, then it might not be the coil. You could try swapping the plug wires at the coil between #2 and #3 to try to check it the #2 post is bad. #2 and #3 always fire at the same time, so it is okay to have them on backwards.
