Old 10-15-2005   #6
x-pride
x-pride's Avatar
Re: New Deck does not turn on
Originally Posted by 4Las90
It's a brand new radio I would hope not. And I believe the yellow wire is a constant wire which burned out and I haven't replaced yet. This shouldn't matter for the radio to turn on it just wouldn't save the memory, it worked with my other radio.
Why did your memory wire burn out? And hell why is the fuse blown? On some radio the yellow wire must be hooked up for the radio to work. Yes I do know what I am talking about. Do you have a mutimeter. If Yes check to make sure you have power at your harness. Power as in your constant 12v and your acc 12v. Also check to make sure you have a good ground. If you want to know if your radio works than do what tim has mentioned. Did you check your main car fuses?
