Old 10-16-2005   #7
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: am i getting false vacuum reading?
Put the #1 piston to TDC as marked on the crank plate, also take out the spark plug to make sure, if the marks on the cam gears line up with the dowel pins pointed up then you are fine. 1 tooth is quite noticable when checking.
Originally Posted by shoutbox
