Old 10-18-2005   #2
Re: Shifter Adjustment Problem.
Some of the 1G cables only had the one adjustable cable. I can't remember what I've done to adjust that. I think I bent the mounting bracket for it. Also, you might just need to replace the cables. I replaced mine 5-6 years ago, they were to far stretched to adjust. Also, make sure the rubber damper on the bottom of the shift lever is not binding or getting in the way.
