Old 10-26-2005   #11
Steeltwo
CompUSA Whore
Drives: 07 Civic Si, 06 IS 350 and I own a dsm
Send a message via ICQ to Steeltwo
Re: EVO no longer being imported to the US??
Originally Posted by ecoli
They should do a more VTECish based version of MIVEC. The variable valve timing stuff that companies like Mitsu and Toyota use is ok, but it doesn't make the kind of power that the alternate cam lobe Honda VTEC stuff does. And now with the K-series Honda motors, they use both the variable valve/cam timing and the alternate lobes.
Hopefully Mitsu isn't going to goto throttle-by-wire also, so that there isn't any standalones available for the car and I wouldn't want a Mitsu implementation of a shitty less responsive torque controlling throttle-by-wire system to deal with.
according to alot of car mags. The mivec has better seemless power. They said it still has a good amount of torque, where as the honda's vtec and yota's vvti lack a bit in the low end department.
91 tsi awd
07 Civic Si
06 IS 350
Steeltwo is offline   Reply With Quote
