Old 10-27-2005   #11
Re: Fuel Cut #2
The only way to get around it is turn the boost down, or run C16 and then lean it way out...
If its only a little jerk or misfire that is NOT fuel cut. The way you guys say the symptoms, to me, it does not sound like fuel cut. Jet put it correctly when he said violent. It is very hard on you and slams you forward as if you just rear ended someone for a couple seconds.
