Old 11-05-2005   #7
Re: clutch issues and other ?s
Several things could be causing the problem. If your clutch disk is sticking to the flywheel due to contamination (oil leak, tranny leak, etc.) or your clutch push rod is out of adjustment, or you need to bleed the clutch system, or you have the wrong step machined into the flywheel, or your tranny could be coming loose from the engine block.
