Old 11-12-2005   #12
top_projects05
top_projects05's Avatar
Re: smoke, smoke and more smoke!
I checked and the oil look pretty regular... So does the coolant... But i guess should run the car every now and then first before i make any final conclusions. That will then tell me if there's any difference in the color/texture or if i'm losing any fluids at all. As soon as i can, i'll check the smell. And yes the car boosts fine when it's cold still. The car has actually been sitting for a month or two now and i've just started to turn it on more often after replacing the turbo. (I couldn't turn on the car then because the old turbo was really mess up. It had a lot of shaft play!) I actually though it was the problem but after replacing it, the turbo wasn't just the only problem.
eclipse gs-t :cool:
top_projects05 is offline   Reply With Quote
