Old 12-10-2005   #3
Re: No start - Fuel?
odd, the same thing is going on with Blue89quest's car. we used my primary in his and it did basically the exact same thing.
clear the codes from your computer first.
make sure you are starting it with the primary (unplug the secondary).
you could test your TPS with a voltmeter to see if it's getting correct voltage and also putting out the correct amount at closed throttle. should be .5 volts i believe. WOT is 5 volts.
check your mechanical min-idle screw. i spose you could try unplgging your idle servo and using the mechanical screw to keep it idling.
make sure the wire from the distributor is connected to it's repective plug and that your mass air sensor is connected and for now, it should be stock.
good luck.
