Old 12-16-2005   #28
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Suddenly super lean while at cruise
I'd make sure its not in RPM mode and its set to the correct size maf you have.
Is your fuel pump rewired? If so, what size relay did you use and did you try replacing that yet? I had a problem with the O-ring sealing on the pump and the car would run perfect with the LICP disconnected but as soon as I hooked it back up it wouldnt run for shit. I know this isnt your problem but it could play a small part in it. Atleast the relay could.
Just trying to suggest anything that could affect the way its running at this point.
Originally Posted by shoutbox
