Old 01-03-2006   #2
CarPsyco84
CarPsyco84's Avatar
Re: Cant shift to 1st or 2nd
1.5cm can be made up by adjusting the length inside the car I think... you could at least try it, that nut looking thing but its like an inch long, with 2 lil nuts at each end, on the shift cable. is adjustable.... You can loosen up the 2 nuts and then spin that big connecting type nut and both sides of the cable either go in or out.... just make sure to leave more than 1 thread in the connector, or it will rip out.... and make you think you broke somthing.....
-When in doubt, Moar RPM.
