Old 01-30-2006   #26
Re: Starting problem
Yes it stays on. Once it starts, it idles just fine, and I can go drive it around too. Sometimes when I am attempting to start it, it will barely start, be all lumpidy and die within a couple seconds. But when I turned on the pump with the logger, and then turned the key when it was pressurized, it started just beautifully.
And when I turn my key, the system does not pressurize. The guage does not move at all.
So if this is the case, what would be stopping this from taking place. The ECU? The FP Relay?
And I will replace those rings as well. Thanks playa!
