Old 03-07-2006   #8
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: 4g64
Originally Posted by CDeutsch
Most people use the same rods as the 4G63 and then use custom pistons. I used Eagle rods and Ross pistons in mine.
You dont need custom pistons (wrist pin hight) unless you are putting a 4g64 crank in a 2.0L block which would make it a 2.3L. Rods, wrist pin hight and bearings are all the same between the 4g63 and 4g64 motors. (6 bolt = 6 bolt and 7 bolt = 7 bolt.. Duh)
The 4g64 has a deck hight 6mm higher than a 4g63, there for since the 4g64 crank has a stroke 12mm larger, 6mm TDC and 6mm BDC... The pistons and rods are the same specs except for the cylinder size making the pistons 1.5mm larger in the 4g64. 85mm bore in the 4g63 and 86.5mm bore in the 4g64. Just some tech info.
Some of you know this but for others who dont...
Originally Posted by shoutbox
