Old 03-18-2006   #11
Onefast99gsx
Re: If you buy a PTE Turbo with Internal Gate.....
Ok.... I did another extensive boost leak test today. I found 5 leaks. I wanted to do this before i tear into the internal wastegate just in case that isn't even the problem. I used a doctors type stethiscope for listening to the leaks.
* 2 joints of my TurboXS blow off valve (At the 90* connector and the hose that connects the bov to the FP intake pipe). I will have to seal with silicone and retighten. Not a huge leak, but IS a leak.
* The little recessed screw on the 1g TB. I believe this is called the BISS screw. Not much i can do about this leak. It's hardly anything anyways.
* The valve cover is leaking where the cam humps are. I think its just the front hump. Will have to take valve cover off and re-silicone over the humps. Considerable leak. 2nd loudest leak.
* The Magnus SMIM has a nice needle sized hole on one of the weld joints. Might be able to weld it without removal. This is probably the loudest of the leaks. Even though the hole is only needle sized.
* Air is coming out the dipstick tube. Not much can be done about this either.
I guess it could be possible that these are why my boost goes nicely to 26psi but then drops down to 20psi through 3rd gear and the traps. I guess I don't know what kind of leak it takes to drop 6psi.
