Old 04-19-2006   #11
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: How much can origional trans take
So with my transmission with a rebuild 20,000mi ago we can assume that it is still kind of fresh. This is a 90s tranny, not as strong as a 91-94 however It should take about 300hp right?
So rules
No hard shifting into gear
no clutchless shifting
Anything else I am forgetting?
Cheap build up of trans
Red line trans fluid would help
Cluch i am guessing needs to be replaced like i stated before
I am guessing those metal shifter bushings would help not to grind the gears. Not that they are grinding now but it is a little choppy
Well time to puke a tranny!!!
I will write a book on how much a DSM will take before it blows up and make more on the book then the dsm is worth
on the otherhand probably most of the people on this forum are probably experts on the subject
