Old 04-26-2006   #11
Re: Internal or External wastegate
Originally Posted by Speedfreak
Because with a larger turbo, its harder for a smaller wastegate to bleed off enough air to keep the boost down. I have a scm61 on a Turbonetics manifold, and a Tial 40mm. I can't keep it from creeping on pump gas. I've ported the manifold as much as possible to get as much air to the wastegate, but with no avail. The placement of the wastegate on this particular manifold isn't the greatest, but in any case, the larger the turbo, the larger the wastegate needed to hold low boost levels.
I have a Tial 40mm off the O2 housing on my SCM61 and it is fine, runs 15 psi. Nash's was the same and didn't have an issue. It must be the placement.
