Old 06-05-2006   #2
JiggahMan
Re: We have compression, spark, fuel, and timing but not a running car. HELP!
Did the ECU you swapped in come off a running car? Does the starter try to crank the motor over? Are you sure you have the right firing order for the plugs? Is the fuel pump rewired?
JiggahMan is offline   Reply With Quote
