Old 06-14-2006   #2
SLOW_V
Re: 1g AWD left front axel Q.
Do you have one problem with axel bearing? Or are you talking about more then one problem?
Anyways, if it is was the hub bearing. I would replace both the bearing rather then one. It is better safe then sorry. If you want the machine shop to press new bearing for you. You will need to take off the entire wheel hub and assembly.
SLOW_V is offline   Reply With Quote
