Old 01-23-2004   #10
Normal compression psi for a 2g is 176psi. This is not a max or exact requirement. Compression can go up or down based on head gasket thickness, machining of the block deck, machining the head surface, camshaft profiles and cam timing, so I doubt you have a mechanical problem to wory about.
