Old 08-21-2006   #3
Boostin_dreams
Send a message via AIM to Boostin_dreams
Re: Wire melted... tail light and dash light is out.
First off when you blow a fuse make sure to put the correct size back in. When you put the bigger fuse in you melted the wire. There was a problem somewhere on that circuit and you need to find it. Could be a short to ground or other wires touching etc. Break out the wiring diaagrams and a test light or voltmeter and start finding your problem if you know what your doing when troubleshooting electrical. If not find a friend who does.
Boostin_dreams is offline   Reply With Quote
