Old 09-07-2006   #28
YiNYaNg
Hold Alt & press F4...LoL
YiNYaNg's Avatar
Re: I must be dreaming! a turbo
Originally Posted by slowbubblecar
It is the one one with the mistu exhaust housing. It is a complete bolt on. Stock manifold and 02 housing work for it. You surprisingly don't even need a spacer plate to clear the water pipe with it.
It's not clearing the water pipe. I had to bang the water pipe alittle for it to fit but it's so damn close to the block the compressor housing is touching the block drain bolt not even a peice of paper can slide in between. I hope I didn't make a puncture on the water pipe
what's a good fix if I did?
Originally Posted by ecoli
Some cars are so slow that even the cops can't tell they are racing.
http://www.myspace.com/kounpheng
YiNYaNg is offline   Reply With Quote
