Old 09-09-2006   #2
iceminion
iceminion's Avatar
Re: 2.4l???
using the 2.0 block you can put a "stroker" crank kit in it to achieve 2.3 or 2.4L displacement. this = $$$$$$.
But 9 times out of 10 they are talking about the 4g64. (same as g4cs)
The process involves finding a 91 hunday sonata, taking the motor.
Using only the block and the crank from the hunday, add all of the stuff from your 2.0 (head, water pump, oil squirters, oil pan, timing junk, etc...) to the 2.4.
TAADAAAAA!! you have a 2.4 monster motor. (you will also NEEEEEED new pistons)
Seems complicated, but its totally worth it, I shall have on sooner or later.
building a 3000GT AWD Turbo.
