Old 09-10-2006   #7
rst95eclipse
Re: Some pics of what I acomplished today
You can use those black paper clip things and clip those to the T-Belt. If you're smart, then it doesn't matter if you cut the T-Belt since you know you'll already be using a new one, which you should. Also, since you're rebuilding, you won't need to have the motor set at TDC. So, you can essentially cut the T-Belt as it is. However, if that's not how you wanna do it, clip the belt to the gears. Remove the gears from the cams by taking off the valvecover and putting a wrench on the cam to stop it from moving. You can then torque off the gear.
I recommend having a rubber mallet to break the head off the shortblock. I found that it helps to break the head loose.
