Old 01-30-2004   #18
Originally posted by b00stingsx+Jan 29 2004, 11:11 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (b00stingsx @ Jan 29 2004, 11:11 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-1ViciousGSX@Jan 29 2004, 09:30 PM
Miss fires will show up as a lean condition, which is probably why his log shows sudden drops in O2 voltage in the higher rpm range. But all that knock could definately indicate a lean condition also.
so are you thinking that im not running lean during these misfires? could i just be running realllllllly rich? [/b][/quote]
It is very possible. O2 sensors pick up the levels of unburned oxygen in the exhaust stream. A miss fire loads the exhaust with unburned oxygen. You need to confirm if you are overunning the mas or running out of fuel pressure also.
