Old 02-01-2004   #21
john
Business as usual
john's Avatar
What boost are you running in that log? You are really lean. You built 35 counts of knock before 6000 rpm. Check for boost leaks or a pinched vaccum line making your boost creep. Do you still have that full 3" intake on the car? That will rub on the wastegate actuator kinking the line making you run alot of boost. Eventually it will poke a hole in the line. If it is rubbing, you caneither bend the nipple on the wastegate actuator or get a intake that goes 3-2.5" that fits. A full 3" intake doesn't help over a anyhow as you are choking it back down at the turbo anyhow.
97 Viper GTS
