Old 10-15-2006   #7
tjg
Re: Transmission wont go into reverse
Originally Posted by niterydr
5th gear popping out is a transmission assembly issue. There is a nut that holds the gear stacks together, that backed off.
Not even feeling the reverse slot is usually an assembly issue. The bolt that holds the reverse gear "assembly" in place could be missing or backed off as well.
99% of the time those 2 problems are transmission assembly issues. Clutch adjustment issues effect ALL gears, not just reverse.
So are the nuts your talking about the ones on the outside like it you took off the cover plate just tight those bolts?
tjg is offline   Reply With Quote
