Old 10-19-2006   #11
Re: Fuel pump not turning on with ignition
You swapped out the large MPI relay under the stereo, right? Check the wiring to the MPI relay and see if you're getting a signal from the ignition. You might have a bad wire between the two or a bad ignition switch.
Yes, that is the relay I swapped out. Stupid DSM's. Whats the best way to check for a signal?
