Old 10-22-2006   #23
tim
tim's Avatar
Re: Fuel pump not turning on with ignition
Originally Posted by ju-on
maybe you gotta slight leak somewhere, so you're pressure is a little low? Injector O-Rings, fuel pump O-Rings, fuel rail O-Rings?
Injector o-rings are new. I replaced them myself. I lubed the fuel feed with a non-oil based lube(sylglyde(sp?)) when I replaced them so they should be good.
